by John Kwong on Wed Dec 23, 2009 1:22 pm
Actually, I do driver coaching but we can talk about that more,if you are interested, when the season gets going. Until then, let me know what you need, info or parts, and I will help you source them. Shifter karts, once they are set-up can be less maintenance between racedays than the RotaxMax karts. Surprisingly, rebuild costs are very similar even though it has the transmission. You should be able to get away with 1 maybe two re-builds during a regular race season depending on how many practice days you put in and if you are starting the season with a fresh motor. Tires and VP racing gas (VP98) are your main expense. I would recommend MG yellow tires, Bridgestone YKB or Vega Blues. These tires will give good performance for 2 racedays plus a practice day and you can run them down till the dimples are gone. If your kart did not come with a padded Tillet seat, I would recommend buying one to make it easier on the body. Our track is pretty smooth but there is a real G-load in a shifter kart that tends to beat on the ribs. If you replace the seat, let me know, there are a bunch of tricks to getting it in the right place so that the driver's weight is distributed properly for good handling. Anyway keep me posted.
John Kwong___CIR Realty___403-294-1500
