Hi All,
I wanted to initiate a "Honey Do" list for our facility that will give members a chance to take on projects to work off their RVF hours.
Re-Paint Scale Pad
- Requires Trem Clad standard medium Blue
Re-Furbish Bleacher
- We have one more bleacher that needs re-furbishing that is sitting at the South end of the facility
- Old plank seating needs to be removed
- Wire brush loose paint off
- 10"x12' planks from UFA
- Hardware to secure planks
Re-Marking of West Parking area with new/more Whiskers
- Whiskers are available at Spatial Technology https://spatialtechnologies.ca/products/stake-whiskers
- Blake Newson can direct you to where these are needed
Weed Whacking
- This needs to be done all season to keep the facility looking good
- I believe there are still gas powered units available at the facility for members to use
Grass Cutting
- The small mower was repaired last Fall and should be good to go, easy to operate
Line painting edge of track
Curb Re-Paiinting
Weed spraying edge of track to control asphalt erosion
Pre-Grid Number Re-Painting
West Paddock needs to be harrowed to flatten out soft spots so when they dry out they will be flat.
Track Crack Filling
- Cracks need to be filled to avoid water penetration and erosion of the gravel base below
- QUAD by LePage would work well for the larger cracks that haven't closed with the frost heaves lowering.
Any further job suggestions?
Strathmore Motorsports Park Honey Do List
Re: Strathmore Motorsports Park Honey Do List
Maybe somebody to paint the new Medic Tower white too, it would make it blend in more? Don
To add to Don's thought- it would also be good to mark it as medical.
- First Name: brian
- Last Name: grant
- City/Town: calgary
Washroom signs. Staples sells women and men plastic signs. We need to buy them and bolt them next to the appropriate doors. no more duct tape, no more sharpies.
