Push Back Bumpers 2019
This is not intended as a point of a discussion but for 2019 ASN Canada FIA has mandated all karts are to be fitted with the push back bumper. For most Karts after 2005 it should be just a retrofit of the attachment brackets that cost around $35 - $40.
If you wish Overdrive MS to order them for you (they do have a certain number in stock) you will need to call Joey and let him know what type of bodywork you have fitted. ASN have given us a 3 race grace period so after round 2 of the ABSO you will be required to have one fitted to use the track.
Joey does also have a Righetti Ridolfi Nose cone bracket combo for around $140 I think... John Kwong will be retrofitting an older kart so if yours is one such kart I would contact John to see what he is doing.
Please do not just sit on this as Joey may need to order in a large stock and past that May 26th date you will not be allowed track access.
I know someone is going to answer !!
Re: Push Back Bumpers 2019
So, even for T&T this will be required, even though there is absolutely no safety benefit? If it will be required for T&T, it will also be required for TAK, which is mostly older karts. I think the bolt-on style bumper support started closer to 2014, so all the older ones will either need to be cut up, and re-fitted, or have the bumper replaced.
I believe this just applies to racing Phil .. Test and Tune Karts only have to comply to our own regulations. I can confirm though.
pauldeadman
First Name: paul
Last Name: deadman
City/Town: Okotoks
Post by pauldeadman »
May as well ask a question :)
When will the penalties come into affect?
1. from race one? Bit unfair if only a select amount of drivers have the bumpers fitted.
2. Or after race 3 when is mandatory?
thanks Fred
Paul
After Race 3 Paul ..... The penalty is mandated by ASN and is a 3 position penalty. This can not be altered by the Race Director.
Please consider donating old bumpers to TAK...
