Vlr
- First Name: Brian
- Last Name: Turner
- City/Town: crossfield
Vlr
Enyone out there have a salution to y I can't get the engine to run lots of fule fully charged battery and button pushed in jimmy and Fred rebuilt engine
- First Name: Evan
- Last Name: Nadeau
Re: Vlr
The red button has to be out to get spark.
Make sure the little wire coming out of the coil is connected to ground. If you follow how the manual says to wire up the coil, you will not have ground.
And or course, make sure the wire coming out of the magnito is connected to the coil.
Pull the plug out, and put it into the plug wire, then hold against the head and run the starter, checking if you have spark. CAUTION: try to only touch the rubber plug boot while holding it to the head to avoid being a shock.
If any of the wiring does not make sense, attach some pictures, and I'll try to help diagnose.
- First Name: Brian
- Last Name: Turner
Re: Vlr
Thanks that helped found a loose wire now it's running almost ready for tomorrow test
- First Name: Evan
- Last Name: Nadeau
Re: Vlr
Fantastic. I'm out in the afternoon if you need any more help, but I'm pretty much a rookie.
I'm number 42. Jankie white electrical tape numbers for tomorrow. haha
- First Name: Evan
- Last Name: Nadeau
