Kart and parts.
Posted: Wed Jan 25, 2023 2:49 pm
- Kart (2018 intrepid) chassis with Lo206 engine. Currently setup for senior but can be changed to junior. The chassis had been spilt, although, Joey had it put on his table and welded a metal rod through the crack. Lap times seemed to be unaffected after. The engine was bought new at the start of the 2022 season and was used for only 4 races. The seat is cracked so either needs to be plastiwelded back or replaced. Includes (a set of rims, a set of used mojo tires, chain, clutch, and sprocket) -$2500
- Used folding Kart stand (big tires) - $250
- Used Mycron 4 - $250
- Brand new wet tires with a set of aluminum rims (never used) -$550
- Trailer bought new in 2022 5x8 foot trailer. Treated plywood bed. Has multiple 2x4 holders attached to frame for easy wall building. Galvanized Steel frame. 6 months old. 16in diameter tires. 1000lbs max load. Comes complete with all the wiring and lighting required for the trailer, a 1-7/8” coupler, safety chains with rated S-hooks and safety latch, and (8) stake pockets. Assembled weight is roughly 260lbs- $1400
- Tr2 mylaps transponder -$90
- Briggs and Stratton 4T racing oil, 10 bottles of 1 litres each - $140
- Tire popping tool -$30
- ~40lbs of lead bricks -$70
