Enduro 2020
Enduro 2020
OK lets start some discussion on the 2020 Enduro .... ideas how to increase numbers , format changes , driver line ups, weight, tires, classes, Do we even still want to run one ? (I have started the change with a Change of direction to Clockwise this year) lets start that conversation ?
evannadeau
- First Name: Evan
- Last Name: Nadeau
Re: Enduro 2020
Our most successful enduros had a rule that you had to have someone on your team that had not raced or held a CKRC or other kart club membership in the last calendar year. This made for a few close calls on the track but also gave friends and family a taste of racing and brought out people who used to race. I would also like to see a mandatory tire change so that teams could use up old tires.
evannadeau
- First Name: Evan
- Last Name: Nadeau
Re: Enduro 2020
John, could that rule perhaps be a smidgen more flexible if implemented? I am a new member this year and have only been to 2 T&T's and 1 race. So perhaps it could have a limitation, like under 5 T&T's and 2 races? Something like that.
Then perhaps a team will pick me up to join them. Also, tire changes sound very cool.
Re: Enduro 2020
Fewer rules has always been the attraction of the Enduro. No weight requirements, open tires, run any current or previously homologated kart motor, dual motor karts, 2-stroke, 4-stroke -whatever. Got a dual Yamaha KT100 setup ? Bring it ! Aixro ? Yesssss. TKM ? Yup-yup, 4-stroke shifter ?!?! Braaaaaap !
I personally hated the requirement to have a non-racing driver on your team; we typically skipped those years as it was not fun and often quite dangerous. The nominal qualifying rule is 107% of pole. For shifters, this means you need to be in the 55's to qualify. A Briggs can be in the 103's and a newbie in a Briggs can easily add 5+ seconds to that. you're looking at 15+ secs/lap difference; the closing speed differential is colossal and the potential for disaster is real. We don't allow Seniors and Jr's on track at the same time at T&T's for this reason so why in a 3hr Enduro ??
Bring back the full LeMans start !
"Back in the day", motors needed to be rebuilt every season (sometimes several times) so the Enduro was a fun way to "use up" whatever was left on your motor before you rebuilt it anyway. Today, motors are much more robust and the Enduro is merely 3hrs "more wear" and doesn't count towards a championship and that's taken a lot of the shine off the event. Maybe a few points to add to your tally for 1st through 3rd for the Enduro ?
Make it accessible and fun and people will come.
Sheriff525
- First Name: Lane
- Last Name: Trim
Re: Enduro 2020
I am looking at doing this with my son. I have never done one before so could someone help me understand the basic rules?
1 kart per team?
Weight classes? I kinda hope not as my son and I are different weight classes
3 hours straight?
1 kart per team?
3 hours straight?
Lane Trim #93 - Briggs Masters
Team Trim Racing
Team Trim Racing
Re: Enduro 2020
Hi Lane,
The 3 hour enduro is one race for 3 hours for all senior drivers. You can have as many drivers on your team as you want but must have at least 2. One kart per team. There was a weight rule put in a number of years ago but I would like the club to reconsider having any minimum weights. There is a 2 cycle class and a 4 cycle class. Motors are stock appearing and normal fuel rules apply for safety.
Re: Enduro 2020
Unless this was changed last year, there is no requirement to have a minimum of 2 drivers; people have run the enduro solo.
The requirement is that every kart must make at least 1 stop. If you are coming in, it makes sense to put a fresh driver in the seat, but you don't have to.
Sheriff525
- First Name: Lane
- Last Name: Trim
Re: Enduro 2020
So when are the rules for 2020 going to get posted?
Team Trim Racing
Team Trim Racing
Re: Enduro 2020
I am thinking
Run what you brung !
No weight
1 Pit stop
3 hours
Being nothing is on the line this year lets just have fun.
No weight
1 Pit stop
3 hours
