GoPro mounting
- sophie
- First Name: Sophie
- Last Name: Anderson
GoPro mounting
I am wanting to mount a GoPro to my kart, preferably on the front, does anyone have any suggestions for how I should go about mounting it?
Re: GoPro mounting
Sophie,
The most common/secure way to mount a Gorpo to the front fairing is with the mount I have linked below. You only use the top half of it, and put two bolts through holes you drill in the front fairing, securing it with washers and nylock nuts on the backside. The Gorpo should also be tethered with a wire arrangement of some sort to the mount.
https://www.amazon.ca/TELESIN-Diameter- ... 9485&psc=1
