SOLD This is a 3 month old Royal Cargo Trailer its a 6x14 with dual axles this one is outfitted with solar power system with a 2000 watt invertor and interior lights as well. this one also has e tracks and cabinets. this was all $3000 up grade with install .. the floors are also sealed outfitted for go karting with tire racking as well
- Rear Ramp Door w/ Spring Assist
- HSS Structural Tube Main Frame
- HSS Structural Tube Uprights
- Screwless Bonded Exterior
- Exposed Steel Painted
- Lighted Corner Markers
- HD Aluminum Door Holdbacks
- Enclosed Wiring
- Galvanized Hardware
- Rubber Mounted Lights
- Aluminum Molding Top and Bottom
- Interior Lights w/ Switch
- Lighted License Plate Holder
- Automotive Style Undercoating
- 24in Checkerplate Front
- 7 Prong RV Plug
- Aluminum Mill Finish Roof
- Side Vents
- Aluminum Checkerplate Fenders
- Drop Spring Axle
- Radial 6 Ply Tires
SPECS:
- Overall Length: 192in
- Overall Width: 96in
- Overall Height: 97in
- Interior Length: 166in
- Interior Width: 69in
- Interior Height: 78in
- Rear Door WxH: 60in x 66in
- Axles: (2) 3,500 lbs w/ Electric Brakes
- Tires: ST205/75R15 LRC
- Rims: 15x6 Steel, 5 Bolt
- Jack: 2,000 lb Top Wind
- Coupler: 2 5/16in
- Platform Height: 18in
- Main Frame Tube: 3in x 2in HSS Tube
- Side Door: 36in x 72in
- Curb Weight: 1,730 lbs
- GVWR: 7,716 lbs
$10,500
2026 ROYAL CARGO TRAILER WITH SOLAR POWER
Nkumar74
- First Name: Neil
- Last Name: Kumar
- City/Town: Foothills
- image2.jpeg (84.92 KiB) Viewed 3779 times
- image0.jpeg (107.3 KiB) Viewed 3779 times
- download.jpeg (17.64 KiB) Viewed 3779 times
- 2JuE7t.jpeg (466.94 KiB) Viewed 3779 times
Nkumar74
- First Name: Neil
- Last Name: Kumar
Re: 2026 ROYAL CARGO TRAILER WITH SOLAR POWER
Nkumar74 wrote: Thu Nov 20, 2025 5:56 pm This is a 3 month old Royal Cargo Trailer its a 6x14 with dual axles this one is outfitted with solar power system with a 2000 watt invertor and interior lights as well. this one also has e tracks and cabinets. this was all $3000 up grade with install .. the floors are also sealed outfitted for go karting with tire racking as well ...SOLD SOLD..SOLD....SOLD
- Enclosed Wiring
- 7 Prong RV Plug
- Side Vents
- Drop Spring Axle
SPECS:
- Coupler: 2 5/16in
- GVWR: 7,716 lbs
$10,500
