Senior rear tires: 6.0 or 7.1???
Mike S
First Name: Mike
Last Name: Steiner
Post by Mike S »
Hey folks. I just assumed that for Senior Briggs everyone uses 7.1 tires on the rear (and hence probably buys the wider rear rims e.g., 210mm) but I see in the CKRC supplemental specs that you can run either 6.0 or 7.1 on the rear. Does anyone run the 6.0s in seniors, and if so, why? I'm prepping Owen's kart for next season, which is currently set up as a junior, so very curious about this before I buy new wheels/tires.
Thanks for any guidance you can provide!
-Mike
Re: Senior rear tires: 6.0 or 7.1???
Hey Mike,
Nobody runs the 6 inch to my knowledge. The 6 inch D2 will be a significant disadvantage just from a mechanical grip standpoint.
Mike S
First Name: Mike
Last Name: Steiner
Post by Mike S »
Jackmazury wrote: Wed Nov 04, 2026 9:21 am Hey Mike,
Ah perfect -- thanks for confirming that Jack. And as always, appreciate the response!
