Hey John,
Great videos, thanks for posting. I'm hoping to get into the sport by the end of this summer and currently looking at the Senior Rotax Max class. I believe the engines are 'sealed', but does this mean that all Karts should produce the same power? The reason I ask is you seem to lose a little down the main straight to the front 4. I'm assuming you're all on the weight limit for the class, which would lead to me think that a) you have slightly less power, b) you're geared differently, c) Carb' set-up, d) they're at WOT sooner or e) (probably this
) you're all equal and I'm going crazy!
Just wondering how even the karts are purely from a power perspective for this class as I believe the engine should produce approx' 28.5hp and as it's 'sealed' they're all very closely matched? If this is not the case, I'd be interested to know more about the performance from the Rotax Max Karts and how it can be optimized.
Hope you don't mind me asking,
Nige.
