Hey Guys,
I am pleased to tell you that I will be your class Rep for the 2012 Race Season!
After tonights AGM it has been decided by the club that for the 2012 season we will be running the Briggs LO206 exclusively for the Sr. 4 Stroke Championship. It was also decided that any previous motor that had been run in the class over the past few years can still be run, but with no points towards the Sr. 4 Stroke Championship.
I would like to hold meeting to finalize the 2012 rules of our class some time in the not too distant future, but realize that December is a busy month for everyone. So... How does a meeting sometime in early January sound to you guys?
Best regards,
Wilson Dolan
Sr. 4-Stroke Class Meeting
Re: Sr. 4-Stroke Class Meeting
Wilson,
Good to see you step up as class rep.
Now that we have the engine transition year behind us, hopefully the class will continue to grow and we will see regular grids of 15+ karts.
Any thoughts on an agenda for that meeting in early January?
So far just:
Possibility of the Light/Heavy classes.
Exact weights for those classes
Possibility of a more clear tire rule (maybe even a spec tire)
Overall trying to align the rules of our class to that of either WCC of ASN rules to ensure continuity between clubs, events, so on and so forth.
Any other thoughts?
Wilson
Any other thoughts?
Wilson
I think most competitors were using the Mojo's by the end of the year. Even though they are not the ASN & WCC mandated 6.0" Bridgestones, you can't beat the availabillity of free tires. The MOJO's lasted a long time and didn't seem to fall off in performance either. More than likely, though, SRA will continue with the Bridgestone 6.0" tire.
I am lobbying on the ekartingnews.ca forum to change the 4-cycle rear width rule from 50" to 53". This will do 2 things: 1. Won't have to cut axle to make 50" rule.
2. Normal sized rear bumper can be used which I think most were using anyway and disregarding the 50" rule.
Anyway the link for this can be found here: http://www.ekartingnews.ca/viewtopic.php?t=2101
You make a valid point John.
We can scratch that from the list. I wouldn't want to open a big can of worms!
Wilson
Wilson
