Hello all,
Just curious to see what a few extras in the box are. I believe there is a speedo on the bottom right, and 2 of the same in the middle and top left.
what do i have?
Mychron 3 Plus Accesories
Jeff_Terns
- First Name: Jeff
- Last Name: Terner
- misc 063.JPG (452.77 KiB) Viewed 12744 times
"If you no longer go for a gap that exists, then you're no longer a racing driver." Ayrton Senna
Re: Mychron 3 Plus Accesories
Hi Jeff,
Here is the same photo marked with I.D.'s
That speed sensor looks like it is for a 40mm axle. I don't use a collar for the magnet on mine. I just put the magnet on the axle and tape it with electrical tape (about 4 or 5 times around). Even though you can plug it in the bottom port on the back of the MyChron, it might not recognize it without the expansion box.
Jeff_Terns
- First Name: Jeff
- Last Name: Terner
I'm pretty sure I have the expansion box. I was fiddling around trying to get the data to download, but I'm not sure about the software and drivers I need, or if that's important enough to fuss over.
Thanks John!
Thanks John!
