John,
You are right it is a 125cc Pavesi, carb on the side. We don't have any jets/spares for it, so hopefully they can get through a weekend without a lot of tinkering.
For the tires, I think Joey had a used set of D3's I could grab. Do you have a used set of the vegas or Mg's you would sell?
Double header weekend Sept 15/16
axle182
- First Name: Aaron
- Last Name: Freind
Re: Double header weekend Sept 15/16
Im trying the Maxxis this weekend. Scrubbed them in last night. Grip level wasnt bad, but the track was really cold so not a good test bed. It'll be interesting this weekend. I have a used set of D2 and D2/D3 (dont ask...) ready to go too.
Looks like we have a great field of Shifters. Is everyone running on both days? If not, post up which day your coming. Im not 100% sure i can make both so id like to choose the day we have the most karts.
Nathan, Joey is also getting some more VP this week also.
Nathan,
I only have one set of used MG's left and I am using them. The D3's should be okay. I also have lots of carb tuning parts but the only big jets are a 195 and 188 jet. The shifter carbs are much less sensitive to changes than the Rotax carbs and can be tuned by changing the clip setting. If the kart has run here before, then the jetting in it is probably close.
I spoke with Mike Henderson and he said he will drive his kart Thursday evening and make a decision for the weekend whether he will come out and run.
So to update the list of shifter racers for this weekend:
1. Nils J
2. Terry F
3. Aaron F
4. John K
5. Ben Y
6. Iain M
7. Nathan
8. ?
1. Nils J
2. Terry F
3. Aaron F
4. John K
5. Ben Y
6. Iain M
7. Nathan
8. ?
Aaron,
I am in for both days. Sundays usually have more racers because some people have to work Saturdays.
axle182
- First Name: Aaron
- Last Name: Freind
Ok ill be there Sunday then. Cheers
