Could someone please help us with the regulation size of numbers on karts? I have looked in the regulation book but can't seem to find any mention of size. We are assuming they should be 6 inch tall. Please advise.
Jen
Kart Numbers
- First Name: paul
- Last Name: deadman
- City/Town: Okotoks
Re: Kart Numbers
Hi,
Go to the downloads section on the main page.
ASN - Tech book 2. paragraph 8.26 discussed kart numbers.
The club has not enforced this to the max although Fred has stipulated rules in the forum for numbers.
Kart Numbers !!
Members are to go to MSR and register their required number (If you held the number last year you automatically are considered the owner of that number this year.
What ever number you have must stay with you throughout the season ... If you buy a Kart with a different number you must change it to your number.
Only real numbers (2) will be accepted as passing tech (No US Numbering allowed (Letters) No tape no sharpie numbers allowed)
Ideally they should follow ASN in Measurements and colours (Yellow background black numbers) although the club regulations allow for different colour combinations if it can not be read easily from the tower it will be deemed to fail Tech. Colour's should contrast to be visible.
Front .. Rear ... and both sides must have a legible number .... You may be refused entry to the Pre Grid if it is deemed that they can not be read.
PENALTY FOR FAILING NUMBER TECH ..... Last Place points START FROM THE REAR OF THE GRID.
Hope that helps.
Paul
Kart Numbers !!
Hope that helps.
Paul
- Last Name: Coroy
Re: Kart Numbers
I am a newbie this year, where do we buy the number stickers? Thanks
- SteveO
- First Name: Steve
- Last Name: Orton
Re: Kart Numbers
Joey @ Overdrive sells the yellow backing and numbers, so that's the quickest and easiest. He's usually at the track most Thursday nights.
If you want customized ones, check online, there are lots of options. godecalzone, eBay, or any of the other specialty shops like JakeDesigns, KartDavid.....
Re: Kart Numbers
Most economical is to make your own by getting the material at Victory Vinyls.
- Last Name: Coroy
Re: Kart Numbers
Ok, great, thanks everyone for your help!
