Page 3 of 4
Re: Laminated Track Maps with corner numbering
Posted: Thu May 21, 2015 7:31 pm
by Ironring Racing
I'll order one. Thanks for setting this up!
Josh Carter
Posted: Fri May 22, 2015 12:28 am
by newson48
I will order some extras, but I want to get a ballpark count as to those who will actually buy one.
The gear ratio chart is an interesting idea. I will think about that. I just don't want any printing from the backside to show through on the main picture.
Perhaps someone wants to send me the charts for all classes? Lots on the go.....
Blake
Posted: Fri May 22, 2015 10:34 am
2 ways to avoid bleed-through are to use heavy stock paper or just laminate 2 separately-printed sheets back to back.
Gear ratios are just that -ratios. Drive gear teeth divided by driven gear teeth. Ratios are independent of class, motor, and chain pitch (although many charts you will find imply they are for a specific pitch, which is nonsense)
If you google, you will find tons. Here's one example that claims to be for 35 pitch
http://www.gokarter.com/gearratio/35%20 ... 0Chart.pdf
I could crank one off in Excel for you in about 10 mins if you need.
Posted: Sun May 24, 2015 9:28 am
by Joey Guyon
I'll take two please
Posted: Sun May 24, 2015 4:15 pm
by Chancery24
Based on my first outing on Saturday, I'm going to need all the help I can get! Pleased put me down for one. :D
Posted: Sun May 24, 2015 10:44 pm
by troubletitan
I found this online that seems to be Rotax Max specific gear ratio chart. Looks pretty user friendly, for input of the required data.
http://membre.megaquebec.net/mtlamla/ro ... alysis.htm
Posted: Mon May 25, 2015 3:31 pm
by Karen165
Please put me down for two maps these.
Karen
Posted: Wed May 27, 2015 4:25 pm
by Visotto123
Ill take one as well.
Posted: Wed May 27, 2015 4:37 pm
by Erin
We will take 2! THanks
Posted: Fri May 29, 2015 7:32 am
by franksartor
Thanks Blake
I will take one
Frank
