Page 1 of 2
Meeting
Posted: Sun Aug 21, 2016 8:36 am
by De Tomaso
There will be a short meeting to confirm the changes for the 2017 Saison .
We will meet Saturday September 10. at Race # 10 after Lunch by the BBQ Shelter .
Markus
Class rep. Senior 4 Stroke
Re: Meeting
Posted: Mon Aug 22, 2016 10:46 am
What changes ?
Re: Meeting
Posted: Mon Aug 22, 2016 11:01 am
Class weight will be adjusted to the same as the ASN National weight at 340 lbs. minimum. I can't remember if there was something else too.
Re: Meeting
Posted: Mon Aug 22, 2016 11:07 am
by DaveC
Tires ... spec to D2 ... excellent write-up of last meeting is at ...
viewtopic.php?f=12&t=2642&sid=bb962c71d ... 2b5f#p7441.
Re: Meeting
Posted: Mon Aug 22, 2016 7:11 pm
by De Tomaso
yes , that is all . 340 lbs and Moto D2 .
If everyone is good with that there is no need for a meeting and we all can spend more time eating Burgers and Brats .
Markus
Re: Meeting
Posted: Sat Jan 07, 2017 9:45 pm
Just as an Addendum to the class rule changes for 2017.
1. Weight change to 340 lbs for Briggs Senior Light.
2. Vega Tires: With the shake-up of the Mojo tire supply for 2017, Vega will pretty much be the tire of choice for CKRC classes. Whether we continue to stay as an Open tire designated class would probably be do-able as the Vega Tire is pretty optimum as a choice for a tire and has already been tested to be about 1.5 seconds faster than the Mojo D2. With that being said, wanting to use the same tire for the Alberta Shoot-Out rounds will probably be the Vega tire.
Thoughts?
Re: Meeting
Posted: Sun Jan 08, 2017 7:29 am
by DaveC
Thoughts from me ...
1. 340 & 375 ... yes
2. The Vega is likely a default choice due to its supply and reported performance advantage. The only question remaining (I think) the 6.5 or 7.1 inch rear tire width. The dealers have recommended the 6.5 inch rear, we (club or class) have not discussed this as far as I know. I would personally prefer to continue to use the take-offs from the Rotax classes as opposed to being forced to buy new tires (especially as mush as I T&T), but an open rule would cover this. I'd support the open rule remaining the same for 2017. As far as the AB Shoot-Out, an open or spec rule in Calgary would not really make any difference, if the Vega performs as reported it will be the tire on every kart (like the D2 was in 2016).
We've also not discussed the wet tire ... I'd personally like to avoid buying another set of new tires to start the season ... if the Vega wets are as good as everyone says, just leaving the rule as 'open' lets those with W2's use them up, and those serious about podiums buy new tires.
Re: Meeting
Posted: Mon Jan 09, 2017 2:17 pm
I'm ok with 340 -less lead for me !
I too am concerned with the switch from 7" to 6". This needs to be discussed and decided pronto as many (most?) don't have 6" rims....
I think most people will say "Let me drive the 6" and compare to the 7" and then decide". Of course by the time that is possible, it's pretty much too late.
Re: Meeting
Posted: Mon Jan 09, 2017 2:54 pm
by Joey Guyon
Hi Guys,
Good discussion and vocalization of concerns.
In regards to the rear rim width and tire width for the SR Briggs, I don't believe we NEED to have just 1 option. We do need however a guideline or suggestion for guys like me who sell new karts to people or karts to new people
for example, I think I should outfit all new karts with 180 rims and 6.5" rear tires.
Now, we can word our regulations allowing:
6.5 tires on 180 rims
6.5 tires on 210 rims (there would be some Tony Illing wordiness saying as per ASN which would mean from 180mm to 214 and anywhere in between as per ASN @ 55")
7.1 tires on 180 rims
7.1 tires on 210 rims
This would allow multiple solutions, of which the most important would be:
Not being forced to be new rims
Being able to use Rotax Take offs
I think the direction however should be the 6.5/180 route, which is already what the J2 karts would be outfitted with. That way if there was to be "a big race" in Western Canada, it would be no surprise when 6.5's were the spec tire
Thoughts?
Re: Meeting
Posted: Mon Jan 09, 2017 6:14 pm
by Team 75
Hi Joey
Could you test all the different combinations and report back to us
Wendell
