Page 1 of 2
Rookie Advice on Weight Class
Posted: Sun Mar 03, 2019 12:34 pm
by Cabel
So after Try-a-Kart last year I knew I'd have to be out to race this year.
I bought a Riccardo DRF-01 w/Briggs from an EDKRA member at the end of last season.
My question is this: Kart & Driver with 1/4 tank of fuel I'm 347lbs.
Is it worth adding the 30 lbs of ballast to drive in the heavy class?
Either way I'm sort of preparing to end up mid field or at the back for most of this season as I learn the ins and outs of racing, the course, and setup but any words of the wise to a rookie racer?
Also should the suggestion be to add the ballast, is Joey/OD Karts then who I should talk to for scaling and weight?
Any other advice to make the most of my first season with you all?
Thanks and looking forward to getting to know many of you this year.
Re: Rookie Advice on Weight Class
Posted: Sun Mar 03, 2019 10:12 pm
I wouldn’t worry too much about being 7lbs over the class weight. There’s a few in light that are over and still run up front. If you do decide to go the heavy route joey is a good resource.
Posted: Mon Mar 04, 2019 8:17 am
by Cabel
Thanks Jack, I guess I was more asking as a older rookie is the light so competitive that I'm better off to add the weight?
I think Steve said the light class was dominated by much younger drivers (I'm 43)
Posted: Mon Mar 04, 2019 10:02 am
The light class has definitely seen an influx of younger drivers, while at the same time seeing a slight decline from the old guard going to masters. This has been largely attributed to the growth of the briggs classes and the greater competition seen because of this. Light is likely the more competitive of the two where as masters is a more relaxed class. This all being said John K is still faster then many (most if not all) people in light who are half their age. If your still deciding after this, maybe try a race in light before going out and purchasing ballast and then decide where to go from there.
Posted: Mon Mar 04, 2019 1:48 pm
by Cabel
Makes sense, thanks! Now anything you can to make spring come faster?
Posted: Mon Mar 04, 2019 2:14 pm
one can only dream
Posted: Tue Mar 05, 2019 5:41 am
by SteveO
Hi Cabel,
Spring is coming, just not fast enough!
Jack's spreading some great advice. Since it's your first year, I'd get out and practice as much as you can without any weight.
When you're comfortable, which might be the first race of the year, jump in the Senior class and see how it goes.
If it looks like the guys your speed, age & weight are in the Masters, then throw on the weight for the next race. 30 pounds is significant enough, but there are drivers competing in Masters that have more than that. Last I checked, lead was around $5 a pound.
Posted: Tue Mar 05, 2019 9:06 pm
by Cabel
I haven’t officially “joined” yet but that’s just the webform and a credit card, I’m assuming I must attend the rookie school before I can use the track for practice? Or might there be opportunities to join veteran members at the track prior to if I sign up early? Forgive the childish exuberance but my new toy has been sitting in the garage since the day the snow flew!
Posted: Wed Mar 06, 2019 8:30 am
by SteveO
If you're a member, and the track is open prior to the Rookie School, you can definitely put your kart on track.
If you are not a member, there is a nominal fee ($50 I think) to be a Test & Tune day member.
Either way, club members will definitely help you get up to speed. We love sharing what little knowledge we have.
However, when you catch up to us, we might not be so willing...j/k!
Posted: Wed Mar 06, 2019 9:00 am
Keep an eye on the event calendar for updates. Once the track is clear test and tunes will begin. We are hoping for mid April.
