Rookie Seeking Feedback: Post T&T Questions
Posted: Fri May 03, 2019 11:11 am
Was so great to meet a few of you last night, thanks for the intros and so great to finally get on the track!
Few small problems, big opportunities to learn thank to Joey and Jesse for the saves!
Some questions:
Obviously my driving has a lot to be desired just yet but I found I really struggled with the back end of the kart wanting to slide out and kind of bogging/stuttering in the corners especially the twisty section (would that be 6, 7 & 8?), I'm sure my driving is the biggest factor but I had some questions about kart setup since I bought it from someone much different height/weight than me:
1) Jose from EDKRA who I bought my kart from was quite a bit taller, I find my reach to the steering wheel I can't hold comfortable at 9 and 3 and kind of end up at 8 and 4), I'm thinking I can't get good weight transfer to lift the inner tire on corners, does this seem right? Anything I can/should do to alter my seat position to make my steering position more comfortable? (Struggling to find much clarity on this via google.)
2) Jose swapped the axle, was supposed to give me the other but hasn't yet not sure when we'll connect, I'm thinking based on his size and weight he went stiffer, will this hinder my ability to lift the rear tire? Could I should I narrow the rear track? (Someone also mentioned my chassis is actually a rotax chassis w/ a briggs, would this chassis be stiffer to accommodate the extra weight/torque of the rotax and would that hinder my ability to flex it in the corners given my shorter stature and lower CG?)
3) Presently no stabilizer bar in front or back, would a front bar possibly help me get more rear tire lift?
4) I had my tire pressures about 10-11 last night, looking at the wear looks like pretty good contact patch overall but seemed like everyone I spoke to was running more like 14-15, that seems like would make my problem worse, but maybe I'm just thinking like you would in a car. Suggestions? (Same vega greens for tires as everyone else) Should I increase all around? Leave the same? Increase the fronts by a couple pounds?
Thanks for the input!
Some questions:
