Hey guys,
I’m curious if more guys prefer the 180mm or 210mm rear tires in Briggs? Particularly in masters. Thanks!
180mm or 210mm Rear Tire
BradWalker72
- First Name: Brad
- Last Name: Walker
Re: 180mm or 210mm Rear Tire
I believe you are referring to the rim and not the tire. Many have tried the 6" tire on a 7" rim and most have settled at 6" tire on 6" rim.
Don't forget that if you try this and are running at max width, you will be over !
