racing in multiple classes
eagle
First Name: Lee
Last Name: Rivey
Post by eagle »
Hello
I am interested in racing a second kart. What i am curious about is if the 2 classes are back to back in racing order?
I found most races this past season, the 2 classes id be joining are always back to back.
For example, first class is a senior, and the second is a master class. Would there just be a slight delay for me to come off the track with senior kart, park kart on side without weighing, and jump in a second kart and then the class is waived onto the track once i move kart into grid slot?
thanks for some info
Re: racing in multiple classes
If you're running two separate karts it's not a big problem. They will let you jump to the front at the scales, weigh your kart, then go join the grid for the next class. Remember that your weight will drop a bit doing the two back to back, so you may find you need to add a bit to the second one. If you're planning on doing it with one kart, and adding/ removing weight, they probably wouldn't appreciate the wait.
eagle
First Name: Lee
Last Name: Rivey
Post by eagle »
Thanks Phil. Good to know the club will wait the couple minutes for someone to come off the track and switch to their second kart. Looking forward to more track time on a race weekend!
As Phil has pointed out, we do if required wait for back to back racers to get to their next Kart. This is the only time we allow overtaking to get back to the Scale after the chequered flag.
Once at the Scale you will weigh in and once cleared place your Kart in Parc Ferme (if required for tech) and proceed to your new grid position and new Kart. Your Kart should be at the grid ready before you take the track for the first race. The reason we always have these races back to back is because its quite unusual for racers to run both Senior and Masters races. We will not wait for any maintenance to be carried out to a single Kart on a double entry. As Phil mentioned you should expect to weigh in around 5lb less on the second weigh in so would need to take this into consideration.
