LO206 Briggs for junior
Posted: Sun Jun 19, 2022 11:54 am
by fast_and_the_curious
Question for new guy, I know the junior Briggs motor is restricted, can a senior Briggs unrestricted be made to restricted easily? Came across a kart for my junior but has the senior engine.
Re: LO206 Briggs for junior
Posted: Sun Jun 19, 2022 12:38 pm
Yes, very simple to change a briggs engine from SR to JR. All you need is a different carburetor slide and a cap lock.
Posted: Mon Jun 20, 2022 11:00 am
There has been some rule changes in the last couple years that could require additional parts. The carbs have changed, and they have been DQing the older ones, so be aware of that if it has an older engine.
Posted: Mon Jun 20, 2022 12:32 pm
Thank you, and how can i tell the difference ?
Posted: Mon Jun 20, 2022 1:33 pm
The older carburetor will say Walboro on the face of the body, the new one has a Briggs and Stratton emblem on it.
Posted: Mon Jun 20, 2022 2:03 pm
Okay thanks,sounds easy enough.
Posted: Mon Jun 20, 2022 4:29 pm
The brutal reality is they have DQ carbs that were stamped Briggs, with the appropriate part number marked on the carb body, but the internal measurement failed. If the engine has orange seals, I believe it should have the right carb. I think it was new for 2020. A new carb is probably $200-250, and outside of the top five, you're not likely to get teched, so it could be worse.
Posted: Mon Jun 20, 2022 6:47 pm
Thanks again,so not the end of the world if it's the old one.
