OTK SHIFTER FOR SALE---SOLD-SOLD-SOLD
RAVEN
First Name: Robin
Last Name: White
City/Town: Banff
Post by RAVEN »
Hanging up the Gloves...sort of....
Selling My Shifter,......$8,750.00... This is a Solid Great Deal...with everything included....
-- This is as close to a new Shifter as possible, with all the heavy lifting done for you..
--OTK EXP RACER Chassis,-- with low hours, Approx, 20hrs., never wrecked, and straight just needs to be driven again!
--Kart was completely refurbished, the winter of 2019 for the 2020 season and has sat in my warm garage since.
--Stripped down and redone ..Red .. by TOP GUN in Calgary
--4 sets OTK wheels-- , 2 sets --MXC , 1 set-- MXJ, --1set-- Alum. for wets all with decent T&T rubber, in tire bags
--2-- Sets body work, new AERO style , mounted, and one original OTK , all mounts in perfect condition
--new graphics , all perfect condition
--FIK drop down bumper conversion on the new body work
--MYCHRON-5 ,.. Transponder, [ pre-subscription ] ..magnetic lap counter,..data key,..all applicable chargers
--Lots of tidy custom touch's to make life easier when race weekend thrashing happens.
--Recent Brake [ August ] bleed done by Jesse at Overdrive
--did I mention I polished a few things....as tidy as they come.....
--ENGINE--
--TM10-C with just under 5hrs on the whole engine, fresh top end done by Joey at OVERDRIVE
-- at that time, original install done by Jesse
-- this schedule should give you 3 more top end rebuilds [ 9-10 hrs.each ] before complete engine rebuild.
--Depending on how many T&T's you do, this equates to 2 solid season or, maybe 3..just saying
-- New Reeds.. New Plug,..New Air-filter,..New fuel lines and filter
--Engine pre-heater ,..New water-pump, New Axle, new axle bearings, gearing 17-27
--Custom rad air deflector, & chain guard..polished ..of course..
--New rear axle bearings, front we're new last season out [2019]
--All new silicone hoses,..and clamps
--Kart stand and -- Overdrive kart cover--to hide all the trick tuning you're going to do.....
--Engine has just had top end run in [ end of August ] and is set to go, [ 3 , 6 min. sessions ]
--As fresh as you can get it without all the hassles.
-- Kart is set-up for 5'11" ,185 lb [suited driver] with 1/4 tank of Fuel, came in 2lbs under class weight
--EVERYTHING BELOW IS GREAT ADDED VALUE WHEN YOU CONSIDER NEW COST AND TIME INVESTED
--TO BRING TOGETHER--
--SPARE PARTS--
--2..40mm axles ---1-N,..1-H,used, and 1-H, new and installed
--5 Tie Rods, 2--Tie Rods with ends, set up for a quick change for wet set up..and 3 Spares
--1--Steering Shaft
--7-- Seat Stays
--2-- Air-Cleaners, used but clean and ready to go
--2--Counter-shaft Sprockets ..New... 16 and 18
--6 rear axle sprockets... 23..24..25..26..27 [alum.]..28 all perfect condition, lots of gearing options here
-- lots of spare chain and master-links
--1--JET BLOCK , Main Jets.. 122..125..[2]..129..130..140..145..148..150..152..155..[2]..158
--3-- INTERNAL Jets.. 1 266 Emulsion Tube..60 Pilot..B-48 Internal Pilot
--2 New Inner Throttle cables
--2--spare TM Engine Frame clamps..[not polished...sorry ]
--1-- Rib-Tech seat.. good condition, not a Swiss Cheese seat....
--1- Box assorted lubricants, All Motul..1- partial, Motul 800 ,1-new Motul Brake Fluid ,
-- partial's of Motul, chain lube and cleaners
--1-Box , Assorted coolant hoses, seat padding etc..
--2-- Lockable, Multi-Compartment case's for other spare parts, lots of goodies here like
--brake pads, tie rod ends , water pump, seat spacers axle keys, to much to list.
--TOOLS--
--1--Chain Breaker
--1--Axle removal tool...[Kart Master]
--1-- Piston Stop [composite material] , threads into spark-plug hole and helps in removing counter-shaft sprocket.
--1-- Bead Breaker , Works great, breaks outer and inner beads at the same time
--1-- Righetti Tire removal and install tool
--1-- Wheel Balance Jig...[Pro-Racing]
--1--SNIPER Front Alignment Laser
--1-- VP Kart Fuel jug..20 liters
--YOU WILL NEED ALL THIS JUST TO KEEP JACK--JAKE--JOEY--AND JOHN...[ sorry Nathan ,You ARE FAST just not starting with a "J" ] ..are you are
--noticing a theme here, with all the J's ? , no wonder I had a hard time keeping you in sight, I was too far down the alphabet....
Happy to talk on the phone or e/mail you the list. Everything goes....ask for Rob.... 1 403 762 8098, home land line ... we will call forward when away from home base....
e/mail....... [email protected]
Re: OTK SHIFTER FOR SALE
Sad to see you go Rob! Amazing kart for whoever buys it.
