Fuel talk - octane, ethanol, etc.
Posted: Fri Mar 01, 2024 2:38 pm
There were a couple comments made during recent club meetings that I thought I might touch on, and thought that members might appreciate a spot to discuss things or ask questions.
I've worked for an oil & gas major for 25 years - most of it spent in the fuels business. While I wouldn't call myself a technical expert, I have, and continue to work very closely with many - who have been happy to respond to my various questions on fuel and lubrication over the years.
Two items off the top:
Ethanol in gasoline
-Concerns are largely overblown. Ethanol gas has a shorter shelf life than pure gasoline, but if it's getting used in a reasonable amount of time it's nothing to worry about. Don't leave it in seasonal equipment as it is prone to attracting water and separating. For the same reason, never use it for marine applications. Nothing to worry about for go-karts, though - unless you're somehow running a decades-old motor.
-Ethanol has about 2/3 of the energy content of gasoline. What we get from the pump is typically limited to 10% (though some jurisdictions are now moving to 15%), so the effective difference is 3%. A computer controlled engine will adjust flow rates to compensate, so in theory you'd see no change in power, but a 3% reduction in fuel economy. In a kart engine, theoretically, you might see a 3% reduction in power - if you could observe such a thing - but adjusting jetting, etc. accomplishes the same sort of thing - adding more fuel to reach the optimal mixture. In short, we'll never see a difference.
-No one is avoiding it. It's been in Regular gas for MANY years. Up until recently, if you REALLY tried, you could avoid it by buying premium gas at certain brands. That ended in late 2022. All fuel - regular or premium - that you'll find at any service station will have ethanol in it. All majors have ethanol in all their gasolines.
Power loss from using PUL in motors needing only RUL
-This caught my attention when mentioned during our meeting earlier this week - I believe coming out of the recent meetings with the Briggs tuners. I'd love more detail if anyone has some - particularly whether they said what caused this, if they had measured it on a dyno or whether it was purely theoretical, and what sort of fuel it was measured on.
-Octane is simply a measure of a fuels resistance to pre-detonation. This means that higher octane fuels can be exposed to higher temperature and compression than lower octane. If a motor doesn't take advantage of this, there won't be a benefit.
-I suspect that the claim that Briggs motors made less power on premium gas is based around the concept of "flame speed" - which is how quickly the flame caused during ignition moves from the spark plug through the fuel in the cylinder.
-There is generally an inverse relationship between flame speed and octane. So, the flame tends to move slower in higher octane gasoline than in lower octane fuel. As you can imagine, having everything go "boom" at one time will generally make more power than if it is spread over a longer period of time.
-I reached out to a couple of our PQ folks to get an idea of how significant an affect this would be. They couldn't give a specific affect as it will vary by fuel and engine. However:
-The difference in flame speed can often vary more between different gas suppliers than it does between regular and premium gasoline.
-We make a special blend of fuel for an F1 team, and specially optimize flame speed for that engine, as it becomes MUCH more important at high RPMs. Theoretically, engines have a maximum possible RPM, as at some point, the piston speed could exceed the flame speed.
-The impact on a Briggs motor is likely negligible. The motor only spins to ~6000 RPM. The displacement is ~200cc, with a ~9:1 compression ratio, which means that when compressed, the air/fuel mixture is occupying a space of ~24cc - so the flame doesn't have very far to travel during the combustion process. This would be about half what it is inside the cylinders of the 2L, 4 cylinder engines powering the vehicles I've got at home.
-In short, this will likely never be noticed in someone's track time or seat of pants. Furthermore, all CKRC members are required to use the same gasoline, so whatever minimal effect may exist, it will be experienced by all participants, equally. If you're racing somewhere else that allows it, go ahead and use RUL - you won't notice any power difference, but you might save a couple dollars for the day.
Ethanol in gasoline
