ISO Mychron 5/2t
Posted: Mon Feb 24, 2025 10:38 am
by Evan_S
We are moving to Rotax this year and understand our Mychron 5 wont cut it.
Any leads appreciated.
Re: ISO Mychron 5/2t
Posted: Mon Feb 24, 2025 10:42 am
by JasonL
You should be fine. The run-of-the-mill M5 has RPM and coolant temp inputs - which is all you really need.
There may be a handful of people that use the 2T to add exhaust temps, but my experience is that this is a minority.
Posted: Mon Feb 24, 2025 12:17 pm
Jason is correct. You can gain a little bit of info for jetting, but the 5 will get you everything that matters. A 5s would provide more accuracy on the GPS side, but you can definitely get by with the 5.
